Too much oil pressure?
Hi, Is too much oil pressure bad? whats the normal pressure at stock when it's cold and when it's hot with a stock oil pump? And same as for when you have a ported& shimmed oil pump. Mine sits at close to 50 when it's fully warmed up with mobil 10-40 oil with thuinderracing ported& shimmed oil pump and when i rev it it hits about 70 or high 60 i'm assuming,but not accurate.
LS1Tech Administrator
Received 1,483 Likes
I used to make just a tad over 40psi with a ported ARE pump and a 800rpm idle speed in my '00 car. Stock pump made about 35ish at stock idle speed.
