100,000 tune-up
Old 03-09-2007, 10:15 AM
bee-stro's Avatar
Default 100,000 tune-up
My car just hit 100,000 miles and i never did a tune-up. What parts do i need and form where? Also which programmer should i get?
Old 03-11-2007, 02:28 PM
bee-stro's Avatar
bump... anyone please
Old 03-11-2007, 03:18 PM
Closed ex-Sponsor Account
autotrix's Avatar
New Platinum AC Delco spark plugs. (along with some anti-seize paste)
Fuel Filter/Air Filter
Injector Flush/Cleaner
De-carbonizer/Seafoam
Clean Throttle body
Noramal inspection of suspension, brake linings and hoses, front end and tire wear and condition.
Hope this helps
Old 03-11-2007, 03:42 PM
Ell Ess Won's Avatar
Prob time for an oil change/oil filter too if you dont know what you need in a tune up.
Old 03-11-2007, 03:48 PM
00PewterSS's Avatar
What did you think you need the programmer for? During a tune up you replace and clean worn "tune" items, not actually adjust your tune. You could get a tune, but I don't think a programmer is the way to go.
You can use NGK plugs also, that is what I'm using, but they won't last 100k.
Brian
Old 03-12-2007, 01:02 AM
BLKWS.6's Avatar
FYI I just pulled a plug at 79500 miles and it gapped at .057'' and looked to be in VERY good shape as well as the plug-wire OHMing out to 270 OHM. My friend's 05 Impala's plug wire OHM'ed at 2800 OHM.Here is a pic of the plug, before you replace, take a look and see what kind of shape it's in. OHM out the wire as well.
THINGS YOU SHOULD DO!
Grease your T-top with GM Dielectric silicon grease
Replace air filter
Replace fuel filter
Clean MAF screen
Change oil/filter
Change diff fluid
Change tranny fluid (ONLY! if you are 6-speed, at 100K miles changing fluid in an un-touched 4L60E is asking for it to take a ****) I see you are A4 so DO NOT FLUSH OR CHANGE FLUID UNLESS YOU DO IT REGULARLY AT 15K MILE INTERVALS OR YOU WILL KILL THAT TRANNY!.
Flush coolant sys./Replace coolant
Old 03-12-2007, 12:22 PM
bee-stro's Avatar
Brian
iohh i know its just since im finally doing a tune-up i want to use a proogrammer also and wasnt sure which one to get...
For the tune-up, I figured i'd use
MSD Wires
NGK TR55 Plugs
K&N Fuel Filter
Recharge the K&N Filter
Get the Fuel Injection serviced (or could i do it myself?)
Change Belts
Fush radiator and recharge A/c = done
am i missing anything else?
Old 03-12-2007, 12:26 PM
Pretyflywiteguy's Avatar
seafoam.. even if there isnt a big change, it's fun as hell
Old 03-12-2007, 12:48 PM
bee-stro's Avatar
whats that?
Old 03-12-2007, 01:23 PM
CrimeSScene's Avatar
Originally Posted by bee-stro
whats that?
You get to rid your neighborhood of any mosquitoes....while pretending your James Bond.
Old 03-12-2007, 02:02 PM
bee-stro's Avatar
ok. how and what do you do
Old 03-12-2007, 02:03 PM
and **** off bikers, i did it last week, which was bike week.
Old 03-12-2007, 04:03 PM
bee-stro's Avatar
what is it and how do you do/use it?
Old 03-12-2007, 04:04 PM
https://ls1tech.com/forums/general-maintenance-repairs/534376-how-seafoam-your-car.html
Old 03-12-2007, 04:10 PM
landstuhltaylor's Avatar
do it with the rear of your car facing your neighbors garden
Old 03-18-2007, 07:39 PM
bee-stro's Avatar
cant find Seafoam at Kragen's, i went to 3 of them. Would Napa sell it?
Old 03-18-2007, 07:44 PM
umm possibly, i got mine from advanced... autozone sells it too.
Old 03-18-2007, 07:46 PM
bee-stro's Avatar
damn... we dont have too many autozone's in my area. the closest one i could think of is 20 miles
Old 03-18-2007, 07:49 PM
02silvaZ's Avatar
don't forget to change your blinker fluid and recharge your flux capacitor
Old 04-02-2007, 11:12 AM
bee-stro's Avatar
did the seafoam, and that **** was cool!!!!!!!! when i took her for the spirited drive, everyone was shaking thier heads as i drove by , thinking something was wrong with the car... now my trottle is way more responsive and the car now drive at lower rpm's... Im changing the plugs and wires this week, hopefully that will bring even more improvement
