Fender sticking out....NEED HELP ASAP
Well I just noticed my drivers side front fender is sticking out a little bit under where the 2 side vents are and above the side skirt....here are a few pics....how can I fix this??
here is a pic underneath...is this whats causing it?? looks like some jackhole tried to jack it up here....i think they did it when I had new tires put on....
What do you guys think?? Can this be fixed?? if so how much??
LS1Tech Administrator
Received 1,491 Likes
Yep, the tabs are pretty flexible, you should be able to bend it back yourself.
This is the reason why no tire shop will ever see my car. I take the wheels off at home and bring them in without the car.
very common mistake when ppl try to jack these cars up. Raise hell at the shop, then get a BFH and fix it yourself that's what I did a long time ago. Then replace your bald *** tires and rusty Y pipe.
Will bending the tabs back with vicegrips fix the fender to door gap issue that is pictured above? I've seen this on a lot of 4th gen f-body's and it looks like it would be hard to get that gap between the fender and door to be even like it was from the factory.
Has anyone fixed this on a camaro with positive results?
my camaro is the same way on the drivers and pass. sides. i tryed twice to fix, but quit. first time with a 3lb hammer and 2x3, second time same hammer but with a brass drift, i didnt think that it moves very easily.
The door gap just goes right back into place once you get the tab straightened out.
Copy & Paste Moderator
Here is your other thread in the Appearance & Detailing section:
https://ls1tech.com/forums/appearance-detailing/677466-fender-sticking-out-need-help-asap.html
