TC questions
TC questions
ok, ive looked up search for this question, an got like 2 pages, an still no help. i was lookin online for a TC on vig's site an saw about a $250 difference between a single-disc and multi-disc converter. wut is the difference? i *think* i remember somethin about one of the posts the reader says all the multi-disc does is help lockup the converter at WOT. if thats the case, can someone elaborate further?
also, wut exactly is a lockup? i looked that up, but got like 250 pages gotta headache after a few pages of lookin, so was wonderin if someone culd gimme a quick rundown of a lockup in a TC.
lock up
a lock up will do just that when at low load. just like the stocker.
helps with mpg and heat. just nail it or tap the brakes and gas it and boom you got the higher stall back
edge
hey also look at edgeracing that is what i have i think they are 565 for a 9" lock up you pick the stall.
I love mine. they say they are good for 650 ish hp range.
I have sprayed mine a ton with no probs
lol so wut exactly does it lockup at? if i had a 3200 stall with a lockup, wut's it "lockup" at when cruising in the city under normal gas usage?
The lock up settings will not be any different than your stock converter. Only way to change when the converter clutch locks up will be to reprogram the ecm. Most stock settings lock up around 30 to 35 mph in overdrive this is under normal acccleration as it changes depending on how much throttle you give it. hope this helps a little
ok, so all the lockup does is lock my tranny in overdrive at ~35mph (stock) under normal driving conditions?
if im right in that aspect, an i get a TC that stalls at ~3200rpm with a lockup, the company is sayin that, under normal city driving, my tranny will lockup in overdrive at ~35mph (barring any gas punches, hard brakes, etc.), therefore keeping my tach relatively low?
