Where can I get a replacement fog light bulb?
LS1Tech Administrator
Received 1,486 Likes
Try Murray's at Waukegan and Oakton in Niles (if you're in the area currently). I've bought them there before.
If you go to Wal*Mart, make sure to look over by the cig lighters and accessories. They're no longer by the headlight bulbs...go figure.
Oh, and put some silicon grease on the seals and connections! The bulbs will last 10 times longer, because the grease seals water out and keeps the connections from corroding.
One last pointer...
Don't touch the bulb part. The oil from your skin will create a hot spot on the bulb and will make it burn out prematurely. Either use gloves, or just be careful. Cheers!
One last pointer...
Copy & Paste Moderator
