Quick question about fuses and such
Old 04-19-2007, 01:00 PM
bret97gsx's Avatar
Default Quick question about fuses and such
On my stock radio, some of the preset numbers don't light up as well as the AM/FM, CD, etc. Is this a blown fuse or something else. If its the fuse, where is that fuse located?
Also my cruise control no longer works, i checked and made sure everything was hooked up, and i also looked at the the AC Cruise fuse in the fuse box under the hood and it was fine. Anyone have any ideas? thanks?
Old 04-19-2007, 01:04 PM
Blk97WS6's Avatar
As far as the radio goes, I doubt its a blown fuse, or else the radio wouldnt work at all. A bulb probably went bad, but you can double check just to make sure. The radio fuse is in the door jam.
Old 04-19-2007, 01:47 PM
bret97gsx's Avatar
where at in the door jam is it located?
Old 04-19-2007, 02:04 PM
2001NBMZ28's Avatar
Like said earlier probably not the fuse - but the panel is on the drivers of the dash, just pull on the bottom of the cover.
Old 04-19-2007, 09:37 PM
Blk97WS6's Avatar
Open the driver side door, look at the end of the dash on the side(facing the door). There is a plastic cover, pull it off, and underneath are all the fuses.
Old 04-20-2007, 08:46 PM
goblue9976's Avatar
Mine is doing that too, but its popping fueses. When the fuse blows, the clock on the radio stays on though...
Old 04-21-2007, 01:28 AM
Blk97WS6's Avatar
Sounds like its grounding out somewhere. Id pull the radio out real quick and see if there are any exposed or bare wires.
