Old 04-29-2016, 05:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Interior Guides
Print Wikipost
Lights Flickering
Old 05-26-2007, 09:23 AM
kraemer94's Avatar
Default Lights Flickering
I just got my 2001 Camaro SS and notice at night while I'm driving all the lights flicker even the dash just enough to notice. I used my volt meter to check the battery I get 12v. I started my car and and check again and I'm getting about a little over 13.5. I check the battery connections all tight and clean. I check also the ground one on the battery side and another on driver side all look good. I ntoice a few people or having this issue. Could it still be the alternator even if it's charging?
Old 05-26-2007, 01:09 PM
staringback05's Avatar
yea, the alternators in these cars suck, so dont be suprised if thats an issue
Old 05-26-2007, 01:35 PM
kraemer94's Avatar
Default alternator
What is a good one to change it with?
Old 05-26-2007, 02:02 PM
im looking for an aftermarket one right now...see my thread in general lsx section...
Old 05-26-2007, 02:13 PM
kraemer94's Avatar
Default Alternator
I found this on Ebay:
http://cgi.ebay.com/ebaymotors/LS1-C...QQcmdZViewItem
They also sell the High Output also.
Old 05-26-2007, 06:03 PM
WannaBcamaroguy's Avatar
I don't know if this is your problem but I remember when I bought my car I would go over bumps and my lights would come on and off inside? I figured out that it was my trunk that was open and I geuss these car don't have a light for when your trunk is open I still feel dumb because I didnt notice it for like 2 weeks lol.
Old 05-28-2007, 02:05 AM
cfiester's Avatar
I had the same problem, replaced the alternator and teh problem went away, i read the voltage output with my mac multimeter and the graph showed 12.8 to 15.9 graph scales
Old 05-28-2007, 10:08 AM
2002ws-6's Avatar
Read the voltage on AC. if you get any AC current the regulator inside the alternator is bad. The ac current is getting through and causing your lights to flicker.
Old 05-28-2007, 05:00 PM
ICEMAN 31's Avatar
i have the same problem, how much will an alternator cost me
Old 05-28-2007, 06:03 PM
ErikElvis's Avatar
My car flickers every once in a while. I just pretend I dont see it.
Old 06-02-2007, 05:26 PM
kraemer94's Avatar
Default alternator
Well it was the alternator. Replaced it light are not flickering anymore. But I have another problem now. While I was replacing the alternator I had to move the tranmission cooler lines just a little now I have a leak I can not see where it's coming from But my guess it's where the lines hookup to the tranmission. Is this a costly repair if I bring it to a shop?
Old 06-04-2007, 07:39 PM
UCABlackChevy's Avatar
Glad to know I'm not the only one.
OP: Welcome to the world of F-body
Old 06-04-2007, 11:39 PM
slowjoe99's Avatar
same happens to me...
Old 06-04-2007, 11:41 PM
phrozen755's Avatar
I did the SAME thing!
Old 06-06-2007, 08:25 AM
silverws600's Avatar
Its the alternator , i replaced mine before my car was totaled on 5-26-07 a month later
______________________
2000 WS6 A4
Old 06-06-2007, 08:50 AM
PEANUT's Avatar
My car also does this, thanks in advance.
Old 06-06-2007, 09:03 AM
Jon5212's Avatar
The only time my lights would dim and come back up is when my cooling fans kick on... anyone else notice this? Happens on the highway as well... its not a flicker, just they dim for a second then come back.
Old 01-08-2015, 12:22 PM
Brandonls1's Avatar
Default 2001 z28 same problem
I checked the alternator at auto zone . Said it was good ? My lights still flicker and I did a code scan on it and it brought up misfires and a shortage ? Could it be a ground by the alternator ?? Plz help
Old 01-09-2015, 12:21 AM
sleepinghawk's Avatar
I had this happen a year after getting the hawk in 05 with just 300 miles on the od. Lights flickered maybe 3 times in a 30 day period. Did that Big 3 upgrade shortly after that and never happened again.
Old 01-10-2015, 08:53 AM
M-Z28's Avatar
Smile
Guys, had the same issue and checked all my grounds under hood. Cleaned them up and fixed the issue.
Quick Reply: Lights Flickering
