Rear End Whines
Old 08-27-2007, 01:33 PM
Canuck63B's Avatar
Default Rear End Whines
Just got a 2001 Camaro SS and it already had 4.10 installed. Thing is I can hear the rear end whine. I've heard some people say it means the rear end is going out on an F body but also heard that it happens frequently with 4.10's. I've taken it up to about 115 on the highway and it didn't have any troubles or anything. Just wondering what the whining could be or mean. Also how much to replace, fix, or rebuild. Thanks.
Old 08-27-2007, 02:56 PM
2tone's Avatar
Could be the brand of gears installed. Richmond gears tend to whine a bit. Or it could be a sloppy gear install.
Old 08-27-2007, 04:35 PM
blade2222's Avatar
check the gear oil make sure it's full.
Old 08-27-2007, 04:39 PM
matt3383's Avatar
when does it whine, under what conditions. My 4:10s will whine on a deceleration at about 50-60 MPH. Depeneds on who installed it and what brand like above
Old 08-27-2007, 07:51 PM
kc533's Avatar
I've got richmond 4.10's and they whine like a ***** at anything above 50mph, they're set up right and everything. You get used to it, plus it's just a friendly reminder that you're driving a performance car
Old 08-29-2007, 08:52 PM
01m6ss's Avatar
i have motive 4.10's in my car and it starts to whine at about 50 mph as well.. some say its the gear not shimed right, while others say it normal for 4.10's to whine..just get some true-duals w/ bullets and that whine will go away..
Old 08-31-2007, 10:53 AM
00TurboTA's Avatar
Is the whine on accel.? or decel? cuz if it is one of those it is most likely a setup problem, but if you have richmonds its most likely just the gears...but check when the noise is it will help u try and see where to start
Old 08-31-2007, 10:58 AM
99Hawk6spd's Avatar
Mine whines on accel, but my rear is completely stock... then again I just hit 104k miles.
