car won't start right
Old 08-29-2007, 03:02 PM
Kratos 2250's Avatar
Default car won't start right
I have a 02 camaro ss and today I was leaving work and tried to start my car and it kept turning over i had to give it gas before it would start could I get some info to why this is happening thanks
Old 08-29-2007, 07:31 PM
GIVE EM' THE BIRD's Avatar
check your vacuum hoses
Old 08-29-2007, 10:49 PM
98Camarod's Avatar
There are only four lines that are hooked up to the manifold. The little one on the back for your a/c, the big one on the back for your brake booster, the one on the front for the pcv, and the other one in the front for something with the fuel system.
My guess would be leading towards a clogged cat.
Old 08-30-2007, 03:05 PM
it does'nt do it in the morning it's olny when I've been somewhere and I let it cool for about 2 hours and thats when it does it, not too sure about this but when you have a vacuum leak does'nt that make you idle go up cause mine is fine it's 600 rpm always
Old 08-30-2007, 04:28 PM
2001NBMZ28's Avatar
Have you scanned it for any codes? SES on?
Old 08-30-2007, 05:17 PM
ses light is on and the olny codes on where #8 cylinder detected misfire I replaced the plugs and wires with msd and bosch plugs and it still comes on any idea why that is going on, oh and I did erase the codes
Old 08-30-2007, 05:58 PM
180ls1's Avatar
the #8 coil pack might be bad but start with the basics to make sure everything is hooked up ok and that you are getting good fuel air and spark for your starting problem
Old 08-30-2007, 06:16 PM
crazymonkey's Avatar
I agree .... I would check/replace your gas filter if you havent done so and also check your fuel injectors
Old 08-30-2007, 06:49 PM
the #1 cylinder injector looks as if it has been leaking slowly wipped it up and have'nt seen anymore could my cat be clogged or do you think this is a fuel prob. ?
Old 08-31-2007, 12:02 PM
sounds like your motor isnt getting enough fuel ..... start small buy some fuel injector cleaner like Lucos(try half tank instead of a full) if that doent work change out your fuel filter (process of elimination) .... it might be simple vacuum leak ...... could be clog cat ....... how many miles are on the car? How long did you have it ? when is the last time YOU did a tune up? what do you have done to it?
Old 08-31-2007, 02:12 PM
I done a tune up on it a week ago it has 99,000 miles on it the olny thing I have done to it is a catback exhaust
Old 08-31-2007, 04:06 PM
what type of tune up (spark plugs , seafoam , flush, filters, belts, fluids)
i wonder if your gas problem directly related to this situation ..... maybe you have a air bubble (back pressure) ....... you need relieve some air through EVAP line you know maybe thats why you can put gas in your car ..... let know if that works
Old 09-02-2007, 11:28 PM
went to advanced auto parts and erased the codes in my computer and it fixed all my problems ? don't know how
Old 09-05-2007, 07:31 PM
ATech08's Avatar
my brothers 98 blazer did the same thing.. check the throttle body 4 carbon build up.. take a can of 2+2 n spray it into the throttle body with the butterfly valve open.. dont spray TOO much.. but it may take a while 4 it 2 start up at first 2 burn the 2+2.. it shuld be ok after that.. if it does it again repeat the process...
