Cam swapping... What accessories to buy?
I plan on swapping out the cam and heads on my car (listed in sig.) i will most likely go with this cam or one close to it: 233/239, .595/.603 112 LSA.
My question is what are ALL the extra parts needed, and be specific, that I need to get to go with this cam? Like springs and oil pump and such...
Also, which heads would you recommend?
Get the cam package from wherever you buy the cam from, it will have your springs, pushrods, gaskets, etc. You should get a ported ls6 oil pump and ls2 timing chain. There are hundreds of threads that cover this in the internal engine section.
Yup dual springs, titanium retainers, hardened pushrods, new ported ls6 oil pump, gaskets, ls2 timing chain. As for heads there are a ton of options out there, so how much are you looking to spend? Livernoise, Patriot, TSP all make good ls6 style heads. If your looking for max effort then AFR, Trickflow, ETP, etc are all top of the line.
Originally Posted by slowjoe99
ummm... i'll spend a lot. what's best?
ls6 is a pretty decent intake, there is no doubt you will see gains with a fast 90/90 over the ls6 intake but that fast will run over a grand. so if your on a budget an ls6 intake is a better choice IMO.
if I get an LS6 intake, would that be good enough for that size of a cam and good heads? of should I get a bigger intake? like 85mm
