lowering springs?
Old 09-05-2007, 11:10 PM
hammerdown2000's Avatar
Default lowering springs?
Is it necessary to change out the shocks whenever you switch out the springs with lowering springs? thanks
Old 09-05-2007, 11:17 PM
Fourced's Avatar
I would highly recommend doing both at the same time..
Old 09-05-2007, 11:23 PM
John02Hawk's Avatar
No, it is NOT NECESSARY, but always a good idea to add supporting parts when lowering your car... (check out the FAQ stickies and also the Suspension forum)
Old 09-06-2007, 12:26 AM
98_Formula's Avatar
probably a good idea, i put sportlines on my car, got new struts for the front but left the stock shish in the back... which means i will probably be doing that work all over again to change it out. just do it all the first time and do it right... wish i would have
Old 09-06-2007, 12:30 AM
TXws6's Avatar
if you have the money buy some shocks for sure man!
Old 09-06-2007, 09:20 AM
greysteel_M6's Avatar
It would be recommended to get an adjustable pan hard rod to recenter the rear end. Measure the tire to fender gap on both sides, they should equal.
Old 09-06-2007, 09:28 AM
JohnnyC's Avatar
Shorter springs will generally have a higher spring rate than the longer stock springs. This higher spring rate will really benefit from a good shock to help control it. The stock springs will work O.K., but will not do a very good job of controlling the new stiffer springs. That’s why you will generally hear people tell you to change the springs and shocks at the same time.
