dumb question... no oil when engine sitting
I'm in the middle of doing some work on the engine, but i worry about everything. Is there any problem with letting the engine sit without oil in it for a few days? I obviously wouldnt be running it (i wont even be turning the crank at all by hand)... but can this hurt anything? Laugh if you want, i was just curious...
Just to inform you...it is no different than your car sitting that long without cranking...the oil settles into the oil pan after a few hours. The oil pump only works when the car is running and that is what delivers the oil to the heads and pistons....your car will last quite a while with no oil in the pan....I wouldn't advise cranking it but you can turn the crank with no problems..
thanks, thats the way i was thinking, but i wanted to be sure.
