Difference b/t 0W30 and 10W30 - LS1TECH
Thread Tools Search this Thread
Old 10-08-2007, 09:16 PM   #1
Vrbas's Avatar
Default Difference b/t 0W30 and 10W30
Does someone mind enlightening me on this?
Vrbas is offline   Reply With Quote
Old 10-08-2007, 09:17 PM   #2
Giggity Giggity
brad8266's Avatar
0W will be thinner when cold. When engine is warm both oils will behave the same.
brad8266 is offline   Reply With Quote
Old 10-08-2007, 09:33 PM   #3
Vrbas's Avatar
So does one perform better/better for your engine? Or does it really matter?
Old 10-08-2007, 10:23 PM   #4
IZRED's Avatar
Quote:
As goes for 1 performing better than the other, I would say no. I would just stick with 5W-30 n 10W-30 like the manual says. The way I do it, is 10W-30 in the hotter part of the year n 5W-30 in the colder part of the year.
IZRED is offline   Reply With Quote
Old 10-09-2007, 08:38 AM   #5
speedthrillsme's Avatar
read about castrol oil 0w-30 on their website or it may be on here somewhere. I use 0w-30 by castrol but it is made in Germany.... has to say that on the bottle.
speedthrillsme is offline   Reply With Quote
Old 10-09-2007, 09:13 AM   #6
Giggity Giggity
brad8266's Avatar
It isnt going to make a difference.
Old 10-09-2007, 06:40 PM   #7
Quote:
we have a winner. there is so much science to motor oils these days with the synthetics on the market. the SAE test is performed at 40C and 100C. that gives you the cold (usually lower number, as in the '5' in 5w20) viscosity first and 'operating temperature' number second.
Quote:
Technically, viscosity is defined as resistance to flow. Commonly though, we think of it as an oil's thickness. To be more specific, it is the thickness of an oil at a given temperature. The difference between multi-grades and straight-weight oils is simply the addition of a viscosity improving (VI) additive. The most common grade of automotive oil in use today is the 5W/30, which is a mineral oil refined to the SAE 5 weight viscosity range containing the usual cleaning and anti-wear additives, then blended with a VI additive that should leave it reading in the SAE 30 weight range when at the higher (210F) temperature. The advantage to the multi-weight is, when starting the engine, the multi-viscosity oil has the thickness of an SAE 5 weight, which allows the engine to spin over more easily.
follow the manufacturer's recommendation for which viscosity oil to use. they have struck the balance between the different metals that're used inside the motor and efficiency vs. wear. in other words, while you probably couldn't hurt your motor by switching viscosity, you won't be increasing performance, either. if you absolutely must spend more money on oil than the average joe, invest in royal purple. it is said to increase performance by 2-5%, which, depending on the motor, can be a significant amount.
jims69camaro is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
German Castrol 0w-30 JOHNNY59 New LS1 Owners - Newbie Tech 21 12-11-2009 12:52 AM
5w 30 or 10w 30 Oil? crapyboy750 New LS1 Owners - Newbie Tech 129 09-13-2009 02:04 AM
Will 5w20 hurt? DlXlE General Maintenance & Repairs 7 09-25-2008 11:19 PM
mobil 5w40 truck and suv oil! CR00SS Generation III External Engine 52 09-04-2006 09:03 PM
Can I mix 5W-30 with 10W-30 ? NOBR8KSS Generation III Internal Engine 4 04-04-2003 12:43 AM
Tags
0w, 0w30, 10w30, 30, castrol, differance, difference, ls1, mobil, nc, ny, oil, sae30, turbo, watertown, winstonsalem
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
