My car is dead!!!
My car is dead!!!
I was changing my battery and I accidentally touched the wrench from the positive terminal to a part of my AC system, now my car is going absolutely nuts. The engine DOES start but the gauges, warning lights, and dome light all flicker on and off. I checked all my fuses and they are all good. I also checked all my ground wires and they are fine. Any suggestions of what to check next?
had you disconnected the negative battery cable first and reconnected it last that never would have happend. try disconnecting both cables NEGATIVE FIRST, and touching them both togeather while disconnected. This will reset the the ram in all your modules and discharge all the capacitors. if that doesnt work you probably fried a module or 2.
