Rattleing over bumps
Old 10-15-2007, 09:44 PM
Jglisson's Avatar
Default Rattleing over bumps
Got a 99 Camaro Z28 that has an annoying rattle when going over bumps (rail road tracks, pot holes, etc.) It is definitely coming from the right side. I just can't tell if it is coming from the front or rear. I have noticed the sound for awhile but didn't notice any problems when I just replaced my front and rear brakes.
No wheel wobble or ball joint problem that I could tell. Do these cars have a common suspension fault area? Any idea what I should look for?
Old 10-15-2007, 09:48 PM
bearcatt's Avatar
Bushings, bearings or rod ends ?
Old 10-15-2007, 10:08 PM
cabech984's Avatar
put the car on jackstands and take a look!! Look for broken sway bar end likes, control arm bushings, etc
Old 10-15-2007, 10:44 PM
blackonblack02_Z's Avatar
Mine had the same rattle when I bought it coming from the right rear side. I replaced the shocks and now all is well!
Old 10-16-2007, 10:14 AM
black01_WS6's Avatar
mine was coming from my exhaust that would hit other metal in the rear.
Old 10-16-2007, 10:20 AM
85Iroc's Avatar
hmmm, mine has all kinds of creaks & rattles...... just assumed it was because it's a f-body. I'm sure it needs shocks with 128,000 on the clock. Maybe I need to look it over for other things too.
Old 10-16-2007, 12:01 PM
Jglisson's Avatar
The right rear bump stop is half destroyed...so the problem is definitely coming from the right rear. The left side bump stop doesn't look like it has ever touched the rear axle any.
Old 10-16-2007, 01:35 PM
98redM6's Avatar
Glad you found out the potential cause of the problem. I had a similar problem with rattles and creak. The rattle was being caused by my torque arm. The two bolts were still in there but the nuts had backed out and were no longer there. I replaced it with new hardware and all is now gone. I recently replaced my rear shocks with konis but I still have a creaking noise coming from the rear when I go over small bumps. I guess I have to apply some grease to some bushings or replace some.
Old 10-16-2007, 03:43 PM
SamhainZ28's Avatar
i had the same problem, my exhaust was hitting something in the rear of my car
Old 10-16-2007, 05:24 PM
King Nothing's Avatar
oddly enough i've had the same problem you did . . . except mine was 1 bolt and it was sheared off completely i need to get under and grease my bushings too cause the creakin noise sucks when your takin a hot girl for a ride
Old 10-20-2007, 04:06 PM
jed.only's Avatar
im guessing either shock or sway bar end link.
Old 10-20-2007, 05:30 PM
grandsport96's Avatar
i had a rattle as well when i went over bumps, and sometimes when it idled... id put 15k down on the table saying it was the rear end and it ended up being the heat shield on the stock exhaust. headers fixed that
Old 10-20-2007, 10:18 PM
boola1341's Avatar
i'm having the same problem with the creaks, rattles and the exhaust hitting something when i go over a bump. i need to get a lube job and replace my shocks.
Old 10-20-2007, 10:35 PM
xXSilencerXx's Avatar
I have a creaking sound in the right rear. I only hear when I go over speeds bumps and things like that. I haven't checked it yet.
Old 10-25-2007, 06:15 AM
ryan1428's Avatar
Dont forget the easy things to check. Ther spare tire and jack bolted down.
Quick Reply: Rattleing over bumps
