Y pipe - LS1TECH
Y pipe
Thread Tools Search this Thread
Old 10-16-2007, 01:23 AM   #1
blackonblack02_Z's Avatar
Default Y pipe
So I have decided to buy a Y pipe for my 02 Z and had a couple of questions.
1. Do the o2 censors thread into the Y pipe?
2. Does any body have an LS1 car with an o/r Y pipe and a dynomax bullet in place of the stock muffler in the back? If so does it sound ok or is it kind of annoying?
blackonblack02_Z is offline   Reply With Quote
Old 10-16-2007, 04:44 AM   #2
WS6 Rampage's Avatar
It should have a bung for the rear O2s if you get one. I know SLP has a really good y-pipe.
WS6 Rampage is offline   Reply With Quote
Old 10-16-2007, 04:46 AM   #3
Where is the bung for the front o2's located? Are they not located in the Y pipe, or are they located in the manifolds?
Old 10-16-2007, 04:48 AM   #4
Quote:
Nope,.. they're on the Cat canister pipe
Old 10-16-2007, 04:50 AM   #5
Quote:
???????? What exactly is the cat canister pipe? Let me just ask this, If I buy a Y pipe am I going to have to do anything special with the o2's other than having the rears turned off?
Old 10-16-2007, 04:55 AM   #6
The Catalytic Converter is welded on both ends to piping, that connects it to both the piece of **** stock manifolds and the y-pipe. On the piece of piping between the Cat and the Manifold is the bung for the front O2s.
Old 10-16-2007, 04:56 AM   #7
Why would you have to delete the rear 02s? !!
Old 10-16-2007, 04:57 AM   #8
The only time you'd probably do that is when you run ORY with LT's.
Old 10-16-2007, 04:58 AM   #9
Oops!,.. Just read what you wrote,.. sorry! So you are running an ORY.
Old 10-16-2007, 04:59 AM   #10
Honestly tho,.. You should probably run that ORY with LT's! Ditch the Manifolds!
Old 10-16-2007, 05:12 AM   #11
Don't really have the money for the LT's right now........... Hopefully soon though! Thanks for the info but let me make sure I understand right quick. So your saying that there is a piece of pipe that bolts to the manifolds, then the cats bolt on to it, then the Y to it? Am I getting the jist?
Old 10-16-2007, 05:23 AM   #12
The jist,.. yes...
Imagine your exhaust as 5 pieces...
1.) Manifolds or LTs
2.) Catalytic Convertes or Cat delete pipe
3.) Y-pipe
4.) I-pipe
5.) Mufler or reonator
The piece of piping that I was refering to is WELDED to each side of the stock Cat. THAT piping is what connects the Cat to the manifold on one end and and the other pipe tis what connects the Cat to the Y-pipe on the other. If you look under your car you'll understand. Basically,.. that piping thats welded to the Cat on each side is PART of the Cat. Especially since the pipe welded to the Cat thats between the cat and the Manifold has the bung for the front 02
Old 10-16-2007, 05:45 AM   #13
So the Y pipe will not actually delete the cats correct? So in all actuallity if I was just wanting to get rid of the cats I could unbolt the piece from the manifolds and the factory Y pipe, cut the cats off of it, and weld a new piece of pipe on. Or am I completely lost now! LOL
Old 10-16-2007, 05:55 AM   #14
Correct,... but ,... Companies offer that piece of piping so you don't have to cut and weld on your own. And it isn't expansive at all! Oh,.. and make sure you get a tune done right away!
Old 10-16-2007, 06:02 AM   #15
What will happen if I do not get a tune done? When I did go to get it tuned afterwards what would they change in the tune to correct for the missing cats?
Old 10-16-2007, 05:01 PM   #16
The tuner would have to delete it! Usually I've heard of cars running like *** when they remove the cats but don't get it tuned out.
Old 10-16-2007, 07:36 PM   #17
Siwel's Avatar
It'll run w/out getting a tune but yuo arent going to get the full gain from what you did. I dont know how common it is but after my Lt's/ORY/Borla my car ran rich as F@#$. I wasent done w/it yet so I just didnt drive it for a week.. Once I got an put on everything else I had in the making for it I had it tuned.
Siwel is offline   Reply With Quote
Old 10-16-2007, 08:53 PM   #18
Quote:
Interesting! I would of thought that you would have been running LAEN as ****! Not RICH!!
Old 10-17-2007, 10:03 PM   #19
Brads LS1 02Z's Avatar
Are u not gettting headers with it??? Not really wort it with out them...
Brads LS1 02Z is offline   Reply With Quote
Old 10-18-2007, 10:57 PM   #20
Sunset'01Z's Avatar
yea you run rich with headers.
Sunset'01Z is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
