skip shift
++ use the search button ++ anyways, what you are getting is computer aided gtear selection (cags) it helps us avoid the gas guzzler tax.
the fix is very simple
goto radio shack and get a $2 pack of 1/2 watt 2.2k resistors
crawl under your car and on the transmission (drivers side) disconnect the little wire harness that is closest to the front of the car
bend the wires on the resistor into a u and insert it into the connector (which should be dangling at this point) and electric tape the **** out of it (tape your new cags eliminator somewhere out of the way)
tape the **** out of the connection on the trans and your done
or, if you want to take the easy way out you can buy an eliminator for aboout $30
Yeah in 4th gen M6 F-Bodys they have computer aided gear selection. The first time it did that it confused me. Its supposed to aid fuel economy so that the F-Bodies wouldn't get the gas guzzler tax.
Normal. Get a skip shift eliminator from one of the sponsors.
http://www.installuniversity.com/ins...adio_shack.htm
http://www.installuniversity.com/ins...r/cags_slp.htm
When the skip shift light is on, is the gear stick supposed to be completely locked from being able to shift into 2nd gear?
If you're able to still shift into 2nd when the light is on, does that indicate damage?
The guy I bought my car from had the skip shift eliminator listed as a mod, but apparently, it stopped working. Because, I still keep getting the skip shift light on and it locks me out of 2nd and 3rd. I just give it a little more gas or press in the clutch until it turns off, then shift though. It kind of annoys me though.
1 Post
i still use my skip shift only because i dont like to see an orange light stay lit on my dash!! ard some guy on this forum was using the skip shift while drag racing, he said he uses it so he does not miss a shift, he engages it with a butten!
I did a quick search on Yahoo! and found a tutorial for installing something that removes something called 'CAG.' The light will still come on, but you're able to shift. I'm praying this is the case with my TA because I can shift into 2nd when the light is on. I was afraid that whatever is supposed to lock out the non 4th gears broke and I'm shifting into 2nd inapprotiately and damagingly.
