What times out of a 99 z28 with a shot?
Old 11-01-2007, 02:05 PM
FranMan's Avatar
Default What times out of a 99 z28 with a shot?
A stock car with says a 100 or 125 shot on it. What should it see in the 1/4?
Old 11-01-2007, 02:10 PM
3rdgentug's Avatar
my bone stock 99 z on street tires here in memphis ran a 13.6 w/ a 2.0 60 ft.
duno about the spray
Old 11-01-2007, 02:59 PM
FranMan's Avatar
So a 100-125 should put it in the 12's?
Old 11-01-2007, 03:00 PM
Pntbll309's Avatar
Depending on your altitude, but it should with no problems.
Old 11-01-2007, 03:33 PM
FranMan's Avatar
how about 11's?
Old 11-01-2007, 04:26 PM
Pntbll309's Avatar
how about 11's?
Most likely not. Low 12's at best and that is at sea level.
Old 11-01-2007, 04:28 PM
TwistedSS's Avatar
Automatic with drag radials and 150 hit puts many into 11.70's or greater.
Old 11-01-2007, 04:43 PM
Pntbll309's Avatar
He didnt say if he had DR's or not. Im assuming not since he said stock. DR's make a hell of a difference.
Old 11-01-2007, 06:24 PM
GIVE EM' THE BIRD's Avatar
easily mid 12's
Old 11-02-2007, 10:04 AM
FranMan's Avatar
With street tires.
Old 11-02-2007, 10:20 AM
3rdgentug's Avatar
yea id guess mid 12's then
Old 11-02-2007, 11:48 AM
FranMan's Avatar
So mid to high 11's would be a bit hard to do? I've heard of a local guy that is said to run 11.7's on 245 street tires. A4 car.
Old 11-02-2007, 12:17 PM
BigDaddyBry's Avatar
Probably has an aftermarket torque converter.
Old 11-09-2007, 09:49 AM
FranMan's Avatar
thanks for the info.
Old 11-09-2007, 11:42 AM
stevez2885's Avatar
Default sprayin
is it possible to run 125-150 shot on stock motor without any problems?
Old 11-09-2007, 02:07 PM
Authrom's Avatar
Depends if were talking wet or dry...If its dry you might have to up your injectors if its wet I dont think you have to do anything for it to be safe.
All of this is assuming your engine is healthy in the first place to be 100% your engine is safe do a compression check. I would also check out the stickys in the Nitrous forum because thats where I am getting this information from.
Old 11-13-2007, 07:35 PM
BriancWS6's Avatar
My car with full exhaust, lid, and 100 shot went 11.87@120.83 on a 1.95 60ft on street tires.
