How to remove IAT sensor to install SLP lid
Old 11-15-2007, 11:27 PM
ryan1428's Avatar
Default How to remove IAT sensor to install SLP lid
Got my stock intake off. Need to transfer the sensor/gromet over the new lid. Its so close to the corner...it is hard to turn. Does it unscrew or do I have to pull it out? Tried to grab it with a needle nose and cracked it. any advice before I totaly screw it up?
Old 11-15-2007, 11:30 PM
SlayerMaro's Avatar
When I did mine with a friend, we just used needle nose pliers. No real trick to it that I know of. If you end up breaking it, you'll just need to buy a new IAT sensor.
Old 11-15-2007, 11:40 PM
ryan1428's Avatar
Do I pull or unscrew?
Old 11-15-2007, 11:52 PM
cryptnosis's Avatar
Pull it.
Old 11-16-2007, 05:56 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
Get some pliers on the inside of it and compress it a bit so you can sqeeze it through. Once you've got enough of it through, push it with your thumb from the inside while your turning it with our other hand on the outside.
Old 11-16-2007, 06:05 PM
2001NBMZ28's Avatar
If you're still struggling with it a couple drops of liquid dishwashing soap makes it a lot easier, rinse and dry thoroughly before using.
Old 11-16-2007, 10:29 PM
the_merv's Avatar
Some of them can be a pain, be careful with it. I just push them out.
Old 11-17-2007, 01:45 AM
ryan1428's Avatar
I think the designer that put the iat in that place should be shot. He must have been smoking crack. I had to completly destroy the iat to get the gromet out. But I appreciate the quick responses.
Old 11-17-2007, 07:59 AM
the_merv's Avatar
Get the Z06 85mm MAF, it's built right into it, and very easy to wire in. That is what I did with my 402.
Old 11-17-2007, 11:20 AM
JScamaro's Avatar
You can remove the sensor to work only on the gromet so you don't mess it up. When I did mine I just pushed on the inside lip with my hands and it came right out.
Old 11-17-2007, 01:14 PM
SchultzLT1's Avatar
ya mine just pushed out no problem....
i dont want to shoot the designer
Old 11-24-2007, 02:00 PM
txh0tb0i972's Avatar
the way i got it out was pushing it out...was a small pain....especially when you want your lid on asap......
Quick Reply: How to remove IAT sensor to install SLP lid
