High Idle
Old 12-06-2007, 07:33 PM
Red
Red's Avatar
Default High Idle
I went to start my car (1998 camaro) and the battery was dead. I give it a jump off of my truck and the motor raced up to 3,000 rpms. I tried tap the gas pedal,check the TB making sure it was not stuck open,but nothing seems to work. Thanks for your help.
Old 12-07-2007, 04:51 PM
LS1>girlfriend's Avatar
weird, any ses codes? when you say checked the tb...you actually popped the hood and opened and closed the tb fully right?
Old 12-07-2007, 04:59 PM
efizjb's Avatar
When you disconnect batteries or they go totally dead the computer needs to do an idle relearn. It's perfectly normal, it will correct itself after a little driving.
Old 12-07-2007, 05:15 PM
2001NBMZ28's Avatar
Thinking it's an idle relearn issue too - get that battery load tested.
Old 12-07-2007, 08:19 PM
Red
Red's Avatar
"LS1>girlfriend" I did open the hood and pushed the TB forward to make sure that the blade was closed. Then I pushed the TB back to open the rpms went higher,so I figure the TB is working properly.
The battery will not hold a charge (dead battery). I recently removed the PS! and installed a short belt maybe the battery is not being told to recharge. I'll go and get a new battery and drive the car around town.
Thanks for everyones help!!
Old 12-07-2007, 08:30 PM
ms4z28's Avatar
i got a 98 it did the same thing dont worry about it just drive it around a little the computer re-learn it program
Old 12-07-2007, 08:43 PM
mine never revved to 3,000 rpm during relearn. when mine relearned it would idle between 500 and 1700 rpm. hope thats the problem!
Old 12-07-2007, 08:52 PM
ms4z28's Avatar
ya mine didnt go quite that high unless i tapped the gas but it only did it once that was after the battery died
Old 12-07-2007, 09:49 PM
Red
Red's Avatar
If the issue does not go away after new battery and a drive around-I'll strap it to the trailer and head over to the tuner.
Old 12-07-2007, 09:58 PM
ms4z28's Avatar
sounds great i would do the same
Old 12-08-2007, 09:47 AM
Red
Red's Avatar
Well,the new battery worked-I started the car and the idle was around 900 rpm's. Thanks again for help everyone.
Old 12-10-2007, 11:26 AM
01ssreda4's Avatar
i wouldn't drop it in gear at 3k
Old 12-11-2007, 05:47 PM
01ssreda4's Avatar
a high idle can also indicate a vacuum leak. one time i shut off my 5.0 and when i went to crank it, the rpms shot to 3500. i looked under the hood and there was a vacuum distribution block and one was popped off. i plugged it back in and it ran perfect. im guessing the vibration of the motor when it stopped popped it off or something. i ended up replacing it.
Quick Reply: High Idle
