LS6 Heads, Cam & Intake on an LS1 Block?
Old 12-10-2007, 09:46 PM
shaneryantomson's Avatar
Default LS6 Heads, Cam & Intake on an LS1 Block?
If I have a stock LS1 aluminum block, can I put stock LS6 heads on it with no modifications or issues?
My logic is that I can add an LS6 intake manifold, LS6 cam, and LS6 heads, and pretty much be running an LS6. Is this correct?
Thanks in advance....
Old 12-10-2007, 10:04 PM
kevin's_00ss's Avatar
yes, just get it tuned and you be making around 370-380rwhp and similar TQ. my bro had an 02 TA with LS6 intake, heads, cam, cut out and off road pipes(stock ls6 manifolds) made 383rwhp through a six-speed. true sleeper
Old 12-10-2007, 10:07 PM
RearMountKing's Avatar
I would def. recommend the Intake... But if you going to do a Camswap, atleast make it count... UNLESS you have plans of Forced Induction down the road!!
Instead of 10-12hp from the cam youll get 30-40.....
The heads are fine!!! I would upgrade to some 918's or somethign similar..
The intake is a great idea, its been proven over and over on this board!!!
Old 12-10-2007, 10:10 PM
true that i guess youll be wanting more any ways..
Old 12-10-2007, 10:22 PM
ae13291's Avatar
yea put a nice cam and maybe port the ls6 heads, that would be even better! (=
Old 12-11-2007, 11:36 AM
DANOZ28's Avatar
well i have the ls6 cam and i think its pretty small. positives, idles at 600 rpm with no lope. sounds stock if you ask me. neg, much lower dyno numbers than i expected. especially if you have a manual trans. there are better cams out there. decide if you want race / max power or good street mannors / drivability. i wish i'd gone slightly bigger and i have an A4.
Old 12-11-2007, 01:38 PM
BurtReynolds's Avatar
Hey DanoZ28! What were your dyno #. I think does 2.73 are really hurting you and without a stall.But Dano is right it depends if you want a race car or street manner car.
Old 12-11-2007, 01:42 PM
CraZee ZO6's Avatar
yea go for it will make some nice OEM style power.
I have ls6 heads cam and valvetrain PM me. LOW MIELAGE take offs.
Old 12-11-2007, 03:04 PM
DANOZ28's Avatar
please no laughing at my crap numbers. (A4) only 349 rwhp dynajet at 13.1:1 a/f only mod since is a 80mm TB. still need 85mm maf, possible under pulley. then its gears which some say does not effect your rwhp. maybe TC? there is a local shop that get approx 20-25 higher numbers, hi tech in anoka but i havent gone there (i want real numbers). i still have torque mgmt turned on , stock timing 28 degrees, lowering my A/F to 12.6 would gain a bit.
Old 12-11-2007, 03:43 PM
ae13291's Avatar
naw j/k those are probly some better #'s then me! lol, but i have never dynoed my car so i wouldent know! so basically wat are your mods???
Old 12-12-2007, 07:04 PM
kw's01z28's Avatar
i heard the cam's in the 98 ls1's were better than the newer ls1's, dont know if they are better than the ls6 cam
Old 12-13-2007, 01:30 AM
ApexVIII's Avatar
the ls6 cam is larger then the 98 cams i think ls1 cams are like 198, ls6 is like 204 or something dont quote me i could be wrong.
Old 12-13-2007, 06:18 AM
02silvaZ's Avatar
basically the same, only minor diff's
Old 12-14-2007, 02:31 PM
ms4z28's Avatar
ya but y put z06 stock parts go better u can easy make over 400 with better mods
Old 12-17-2007, 08:08 AM
DANOZ28's Avatar
diff on cams between 98-99 and 01-02 , lift is about 498 for 98-99 and only 475 for 01-02. just remember 01-02 got ls6 intake and better exhaust manifolds. oh, ls6 cam is 550 lift and 218 / 204 duration. ls1 duration is about 200 / 204 .
Old 12-17-2007, 08:35 AM
onecamaro1's Avatar
i have what you were asking about, and i love it. Perfect sleeper.
Old 12-19-2007, 02:39 AM
jmdale1984's Avatar
For a nice sleeper combo, do the LS6 heads & intake, but get a better cam. Lingenfelter GT-11 cam... idles like stock, but runs like a bat outta hell. Just put one in mine with LS6 stage III heads... WOW is all I've got to say.
