02 sensors
02 sensors
How many 02 sensors does a 99 z28 have ? I havent had much time to get under it lately. Also im throwin a code for an 02 sensor and it says Bank 1, which one would be bank 1 ?
If you're stock you have four. Bank 1 is drivers side, Bank 2 is passenger side - and Sensor 1 is precat, Sensor 2 is post cat. The code will tell you which one it is. 02 codes always specify Bank __ Sensor__.
Don't buy any without posting the code first - could be a symptom of something else going on, for example the post-cat sensors monitor the efficiency of the cats...you may already know, just don't want you buying one you don't need.
The code discription does say bank 1 number 1, so that would be drivers side pre cat , is that right?
