225 heads or 205s
225 heads or 205s
i have a 98 ls1 camaro i used to have a lt1 with lt4 heads i just got my ls1 . i want to build my car. should i build the block or should i just add the head and cam on stock block i also want to go later on down the road with ether TT or sts . is the 90mm the bigest intake
are afr heads the best heads? let me know thanks ..............
What they said. 225's will hurt you more on low end then help. Then again. For later down the road. If your going to TT it then you need forged internals and then the 225's would help quite a bit. It really all depends on how soon all of this is goin to take place. Just my opinion, but either way, good luck
a good performing h/c motor now....or a blower motor for later...
2 totally different engines...figure out which you want to do now...go from there.
what you build for a blower will hurt your N/A power. and vice versa.
