Question about plug wires
I have a 2000 Trans Am I just bought and I am replacing the spark plugs for the first time with NGK TR55 plugs. What I was wondering is I was thinking about replacing the plug wires. Is it worth it to put the high performance MSD's or would I be better off to just go back with the stock ones. The reason I ask is the stock ones are $50 for the set and the MSD's are $130. Also would I even notice a difference with the MSD's?
LS1Tech Administrator
Received 1,483 Likes
$130 for MSD wires is a rip off.
You will not notice a difference with them, unless your stock wires were shot.
1 Post
i got my msd wires for $60 from ebay new, the #8 plug is the only one ur going to need alot of patience
for, i had stock exhaust manifolds so i think its harder because from under the flange was right in the way! and from the top i couldent even see the plug!! so good luck on that one!!
but i had my brother put the plug in from the top and i was guiding him from the bottom!
I gained 4whp when I switched from 7mm AC Delcos (8K old) to 8mm Crane FireWires (which are currently out of stock at Crane in case you're wondering).
Two hot pulls with the AC Delcos and then 2 hot pulls with the FireWires because I doubt my friend (who's my tuner) that they'd make more power. I was wrong.
1 Post
yea my hands were toast!! i was also surprised that my factory plugs were NGK, and my plugs were stuck in the heads pretty damm good!! it took more then a few cranks on the ratchet to start loosening them with my finger!
LT1 plugs are easy. the LT1 wires are a pain in the *** period. LS1 wires are pretty easy. number 8 i had to do from the bottom. as for the plug, i got it from the bottom to, just had my brother guide the socket on. air tools kick ***!
Anyone ever use the Moroso Super 40's or whatever they are. the wires with the thick insulation on them? had them on a 383 once upon a time, didnt know how good they were for the ls1.
