New engines? (in case mine blows)
Old 01-03-2008, 11:28 PM
wrxrick's Avatar
Default New engines? (in case mine blows)
Just curious as to where I can find a brand new short block (in stock form) in case the one I have blows? The cheapest I've found so far is $2700.
Old 01-03-2008, 11:30 PM
99z28monster's Avatar
dickey scoggins
Old 01-04-2008, 07:13 AM
bryan04h's Avatar
ls1 short block? junkyard and rebuild it and you will spend a lot less than 2700
Old 01-04-2008, 05:42 PM
WS6 Rampage's Avatar
Location: The dirty taint of the country. ...Los Angeles
DUDE!,.. If the core is still good I'd just rebuild it with a forged bottom end.
Old 01-04-2008, 07:22 PM
shoemike's Avatar
i think this is the pn for a long block 89017652
Old 01-05-2008, 09:26 PM
venomhp's Avatar
if you blow your motor most of the time your block will be fine, esp an ls1 block, just have it rebuilt with new sleeves and pistons/etc for a lot cheaper than that, or do it how everone else on this board would do....UPGRADE!!!!
Old 01-05-2008, 10:56 PM
raceme@you'dlose.com's Avatar
LS6 crate motor from SDPC. I got mine and with headers and a lid I put 360 to the tire with a completely safe tune AF are 13.0 all the way across. Stock idle, stock drivabilty and I have surpreised more than my share of Vettes and other F-body's. Mustangs don't count because they are too easy MOST of the time.
Old 01-30-2008, 06:22 PM
Fast99408's Avatar
for that price i would get a 6.0 liter block for $300 and bore it out and get a 408 stroker kit for $2200 then you really got a motor or you can just forge the one you have
Old 01-30-2008, 08:58 PM
FMX05's Avatar
Yeah, when mine goes out its gonna be 427 time.
Old 02-03-2008, 05:41 AM
..just have it rebuilt with new sleeves ...
LS1s Can't be resleeved unless your gonna go Darton.
But like I said earlier,.. If the core is in sound condition then I'd just invest in a forged bottom end. HELL,.. you can still reuse the stock Crank(if your gonna stay with stock cubes) as long as you didn't spin a bearing. Reuse the stock heads but have em milled and you can run a higher compression ratio.
