Tightening headers question.
Old 01-13-2008, 02:37 AM
slowjoe99's Avatar
Question Tightening headers question.
I have Pacesetter coated longtube headers. I always have to tighten them. Is there some way to fix this problem?
Old 01-13-2008, 02:51 AM
jetlag's Avatar
Torque them down to the proper specs?
greinder03's Avatar
i dont see why it would do that. are you going thorugh and tightening them several times going in a pattern?
Old 01-13-2008, 02:53 AM
Randi820's Avatar
which bolts did you use?
jetlag's Avatar
I had it happen to me one time, but that was only once because I didn't torque them down enough... otherwise I have no idea what the problem could be.
Old 01-13-2008, 04:14 AM
slowjoe99's Avatar
how many foot pounds?
Old 01-13-2008, 03:10 PM
lifeisgood's Avatar
ive always been told to tighten the heards while warm, that way when they cool the heads shrinks tighter to the bolts. its always worked for me
Old 01-13-2008, 03:29 PM
sidewayz28's Avatar
i never follow a pattern when tightening my headers, i just do them tight as hell. never had an issue.
Old 01-13-2008, 03:59 PM
01ghostwhitez's Avatar
Did you use locking washers on the header bolts? If not try it and that should fix the problem.
Old 01-13-2008, 04:12 PM
Gaunt's Avatar
whatever you do, don't over-torque them.
Old 01-13-2008, 10:32 PM
SladeX's Avatar
aluminum heads, do not torque them down past recommended. I think that's 11 ft/lbs on the first pass (middle to out), then 18 ft/lbs on the second pass. I haven't had any issues with mine since installation.
Old 01-14-2008, 05:15 AM
waldershrek's Avatar
Torque them to specs and use the locking kit, you won't have anymore problems.
Old 01-14-2008, 11:28 AM
jmm98LS1's Avatar
What gaskets did you use? Do you keep tightening them because the bolts are actually backing out or because you hear a leak?
