idle trouble
idle trouble
i recently installed a new cam 232/234 595/598 112 and a pcm from pcmforless and now when i start my car i have to hold it on 1200rpm for a little bit to get it to idle and when i go to stop if i not running at least 2000rpm before i go to neutral it dies. any sugestions?
Simple fix, open the throttle blades a bit. When you scan it you will find your IAC counts maxed out to 160 counts. Open the throttle blades so that you get it down to 30 to 40 and then adjust the TPS to .67 volts at idle and all will be well. The vehicle is basically choking to death since the IAC is at it's max and is not able to open up enough to allow in the necessary air for idle.
If you need any help drop me a call,
Bryan
Bryan
