Problem Starting Car - Need Help
In the past month or so, my car has been acting up on startup. Every few times I get in it, I push the clutch in, put the key in, turn the key, and.....nothing. All the dash lights come on, the radio works, I have all electrical functions and power, but it doesn't even click or try to turn over. I try pumping the clutch pedal a few times, but usually I just have to wait anywhere from 2-5 minutes, trying it periodically, and then all of a sudden it just starts like there was no issue. It never has trouble actually starting (like stalling, etc) if it starts; it just either starts or it doesn't and there are no other symptoms.
Today I went out and it did the same thing, so I tried and waited and tried again for about 10-15 minutes or so with no luck. It seems to be getting worse and happening more and more often. Has anyone seen this before or know what the issue might be? Any advice would be appreciated. Thanks.
Yeah, I've come up with ignition switch, starter relay, or the starter itself crapping out, but I would just wondering if anyone else has dealt with this issue before. I'm not much of a mechanic, so I'm not even sure how to test out the relay or the ignition switch to see if they could be the problem.
OK, I've been doing a lot of reading and it appears that a few people have run into this same problem and they found out the contacts on the ignition cylinder were shot from "normal wear and tear". My car's got 66,000 miles on it, so I assume this could be my issue. They replaced their ignition cylinder and were fine, so I'm going to test anything that's free to test and then probably resort to that.
Any other info or advice will still be appreciated, though.
