T top leak fix?
Old 02-05-2008, 01:12 AM
squeals99's Avatar
Default T top leak fix?
well my t tops leak sometimes between the window and t top, and i was wondering if there was any way to fix the leak? the windows are lined up correctly, but i think the weatherstripping on the outside of the t tops are getting a little old
do they sell actual replacement weatherstripping for the t tops? and if so, is it hard to install? like does it require gluing or bonding it on, or is it just fitted or what?
thanks
Old 02-05-2008, 01:34 AM
Usasoc's Avatar
Im sure they sell it but im not exactly sure where.
I've heard of some guys putting silicone grease on the seals to prevent leakage.
Old 02-05-2008, 03:53 AM
waldershrek's Avatar
Yes you can get replacement seals. They are kind of a pain to put on put not too bad. You will definately want a helper when you do it. The grease that Usasoc is talking about is more for preventing leaks than fixing ones that have already started.
Old 02-05-2008, 04:00 AM
squeals99's Avatar
where would i look to to get a set of replacement seals?
Old 02-05-2008, 04:18 AM
PM sent
Old 02-06-2008, 07:55 PM
pitbull14218's Avatar
mine has a slight leak too, i dont know if its worth fixing. If your standin at the driver door its the front part of the t-top leaks a little near the window. sometimes it drips on my leg.
Old 02-06-2008, 07:58 PM
Twigs's Avatar
same here... can I get a link to the weather stripping also?
Old 02-06-2008, 08:39 PM
slayerized6's Avatar
http://www.youngsfbody.com/9302weatherstripping
Old 02-06-2008, 08:41 PM
T A WS6 M6's Avatar
If it's not too bad, try some baby oil. It may puff the seals back up well enough to do their job.
Old 02-06-2008, 08:46 PM
newton's Avatar
Exact location for me too.
I know it's no fancy Euro car, but sometimes I really wish GM implemented the automatic raise window/lower window feature when you open the door.
Old 02-07-2008, 06:03 AM
qwk93ta's Avatar
Ford did this with the new Mustangs! lol
Old 02-07-2008, 11:35 AM
00'blkss's Avatar
my t-tops leaked bc the car was tweaked from racing it but when i put the roll cage in it, it stopped leaking. Kind of an exspencive fix i know but that was my problem, the car was tweaked even with sub frame connectors
Old 02-07-2008, 11:42 AM
Z Fury's Avatar
My T-tops bleed in that exact same spot, and it was really bad with my '94. However, I found something that kinda helps (maybe). When you are rolling up the window, roll it up with the door open. I have been getting a better seal when I do it this way, as if the weatherstripping itself was blocking the window from going up all the way. Not sure if that will help anyone here, but it works for me...
Old 02-07-2008, 11:25 PM
WhiteFormula98's Avatar
electrical tape...lol
Old 02-07-2008, 11:30 PM
sweet-94z28's Avatar
I like to put my windows up when the door is open. The windows don't align perfectly if you don't. Mine definitely seals better
Quick Reply: T top leak fix?
