9" rear end questions
ok, so im a n00b, and i have heard some horror stories about the stock rear ends in these cars. so, where can i get a beefy 9"?
do i need a different driveshaft with a 9" rear end?
thanks guys!
thanks guys!
well we (my father and i) currently own an lt1 A4, but i plan on getting an ls1 A4 (i suck at driving stick) im not sure how much power im looking at (always changing my plans) but i know i want a bullet proof rearend and tranny. the tranny is no problem, i can figure out how to beef that up. im just used to my dakota R/Ts 9.25 rearend that i can beat on all day long without ever giving it a second thought. thanks guys!
If you have an A4, you're gonna want a 12 bolt...for sure.
Moser has really nice stuff, Midwest/Strange is even Nicer and for a better price...
But you're gonna need a Torque Arm Bar, crossmember relocation kit, and yes You'll probably want a Drive shaft in the future. But a 12 bolt is for sure the way to go for an Automatic. And a little heads up, you're also gonna be paying about 2,400-2,800 for the rearend... From a Moser Dealer that is... and then you'll still need the Torque Arm Bar, and the Kit... +400.00 and the Drive shaft +300.00-400.00...
But if you want to get a hold of Eric at Midwest Chassis and Performance, he could get you all that stuff for well under what I just told you.
You'd probably want a True-Trac Diff, with 31 spline axles etc
Do you have a Torque Converter and stall kit yet?
i dont have the car yet. im making plans so i know where to go once its in the garage. we havent decided what we are doing with the LT1 yet.
A driveshaft is a must for anyone looking to launch the car hard on sticky tires. A 3.5" aluminum or 3" steel driveshaft would be your options, unless you go with something really expensive but not necessary unless you're making BIG power.
And a better rear is absolutely a must for just about any LS1 Fbody, even stock ones sometimes. A 9-inch or 12-bolt are the most common choices.
