Which Pushrods?
Which Pushrods?
I got a set of 243 heads off a GTO
They come with the patriot gold duel springs with titanium retainers.
Heres the question. What size pushrods should I get to go with the Torquer V3 cam?
Can I use the same pushrods with the Torquer V2 Cam?
Is there a big difference between these 2 cams?
I have the opportunity to get some 7.45 pushrods for the cam, but I am thinking those are too long. Anyone confirm?
Will the springs work that come with the heads? They are good to .650 lift from what I read.
Do I need to replace or change my lifters?
Is there a big difference when going to aftermarket lifters?
What head gaskets should I use?
Also, I know that different years have different thicknesses, these heads have never been worked and I bought them with 7500 origional miles. What thickness should I go?
Should I have these heads checked to see if the surface is flat, even tho they have very few miles?
TSP recommends 7.400, but I picked up 7.425 as they said those would work fine as well.
Yes.
Only on the intake side of the lift. .649 for the T3 vs something ~ .598 for the T2. T3 uses a LSK lobe for the intake and XER for the exhaust. On paper, T3 might put down a few more HP and TRQ, it's just a matter of where the torque curve is. I've seen some impressive T2 graphs.
I would take a stab and say that's too long, but don't quote me on that.
Yep, .650 lift will work.
I did. It makes to sense to upgrade while you're in there. LS7 lifters can be had for ~ $100.
Maybe in price if you drop some coin on some Morels. I would just stick with the LS7s.
Stock GM MLS is what I used. You may get away with a Cometic .040 gasket, but I'm not sure on the PTV with the T3.
See previous. Stock GM I *believe* is .051. Check PTV clearence.
Chances are pretty good that they are flat. You gasket will make up for *slight* imperfections, which there should be virtually none.
Yes.
