f-body ls1 vs. corvette ls1 vs. ls6
what is the difference between the f-body ls1 and the corvette ls1. Also is the only difference between the corvette ls1 and the ls6 the valves? i'm planning on finding a wrecked f-body or corvette for under 5000 to use a lot of the drivetrain in a 240z. It will have the weight of a japanese car and the power of chevy. It'll run 12s.
LS1Tech Co-Founder
Re: f-body ls1 vs. corvette ls1 vs. ls6
12s? More like 11s if you put good tires on the 240Z.
Corvette vs F-body LS1:
-exact same heads
-exact same block
-exact same crank/rods/pistons
-exact same intake manifold
-slightly different cam specs (negligible)
-different shaped oil pan
-different serpentine belt pulley layout
Corvette LS1 vs LS6:
-different head castings (LS6 flow slightly better stock)
-different intake manifolds prior to 2001 Corvettes. All 2001 and newer Corvettes and F-body LS1s have the LS6 intake.
-different cam specs (02-03 LS6 cam is much better than 01 or regular C5)
-different PCV system
-slightly different block internals (crankcase port windows larger on LS6)
-same crank and rods, I believe pistons are a bit different
-exact same heads
-exact same block
I hope your right about the 11's but since a stock camaro weighs about 3400 and runs mid 13's if you use 100lbs equals one tenth in the quarter I am estimating that a 2000 lb z will be in the mid to low twelves with some good rubber wrapped around some 17 x 8 wheels. But back to the original question. Are you saying that pulleys are the only difference in the f-body ls1 vs vette ls1. I am leaning toward a camaro because i have found a couple with bent frames and destroyed bodies that have perfect drivetrains for around 5000. I am thinking my best bet is the f-body set up with a bad *** cam. I think the ls1/ t56 setup in a z should at least if nothing else a lot of fun. If you have any other ideas for a z i would love to here them. I am only 15 so i have till next april to get it running.
LS1Tech Co-Founder
Yep, basically the pulley layout and the oil pan shape. Corvettes have a flat oil pan with "wings" on the side, which don't really fit in any other vehicles very well.
There are quite a few bolt-on LS1s running mid-high 11s with no internal engine modifications, all in the 3100-3200 lb range. 2000 lbs is way light!
Tony
Tony
The location of the alternator is different which is what I think Tony means by pulley layout. F-body alt. sits driverside, opposit the a/c compressor. Vette alt. sits driverside topside. Also, the crank pulley are slightly different.
Sounds like you've got the makings of a pretty basass little ride.
thanks for the help. I am pretty sure i am going to go with the camaro because of price. I am pretty sure i am getting a z but my dad has a lot of input and he has told me i cold get a z in the past but i will definatley have to hide these numbers from him till its built. by the way what bolt ons are guys using to run 11's.
STF veteran / 10 second club
-by the way what bolt ons are guys using to run 11's.
uhh.. all of them, i think.
Administrator
I'm no expert here, but LS6's have magnesium valves too to reduce reciprocating weight correct? Tony you'd probably know if that's true or not. I'm pretty sure it is.
I think the LS6 valves are hollow stainless steel and the exhaust valve is sodium filled for cooling (valve stem pics http://www.idavette.net/hib/02ls6/photos/43106b.jpg). Here two versions of the same article about the LS6 development from a GM engineer.
http://www.c5registry.com/Documents/ls6/INDEX.HTM
http://www.idavette.net/hib/02ls6/listpages.htm
Enjoy....
Enjoy....
Magnesium Valves?!!! Since magnesium is flammable ( i.e. magnesium flares), I don't think so. Wheels, suspension, etc., maybe. Engine parts (at least around the combustion chamber), No!!
