ls1 conversion q's
ls1 conversion q's
well im all set on my upcomng ls1 conversion. 95 v6 to 2000 ls1 motor! now i just need to figure out what rear end i should use. should i gear it myself? i heard power trax is ok...or should i just get a z28 or ss rear end? help! what rear end do i have now? 7 1/2 10 bolt?
Last edited by Josh Judkins; 03-02-2008 at 12:16 PM. Reason: had to add question to original post
The rear used in the V6 cars is the same as the V8 cars strength wise. Being you have a 3.4L V6 it probably has something better than 2.73 gears, but because you want disc brakes and the posi I would just swap the whole thing. It's going to cost way more to upgrade the one you have than a good used rear will cost.
Re'
Re'
