Quick Response
Old 03-05-2008, 03:03 PM
RedJackal's Avatar
Default Quick Response
It is pretty bad I'm asking this, but it would save me an hour of trouble. Where can I find the Turn signal Fuse? (Passenger side) I have checked the side box, and the two under the hood. Anywhere else?
Old 03-05-2008, 03:23 PM
2001NBMZ28's Avatar
Should be on the panel inside the car, mine is listed as TURN B/U for the flasher. If it's just one side not working look for a burned out bulb.
Old 03-05-2008, 03:39 PM
RedJackal's Avatar
Bulbs are working fine, went to auto store and got a new fuse but its a large round one that their computer rang up. Is that wrong? the Turn B/U is a small fuse like interior lighting, you sure thats the one?
If it seperats some confusing, I meant to say Flasher Fuse.
Old 03-05-2008, 06:11 PM
sreve's Avatar
sounds like you bought a flasher not a fuse. with the bulbs being ok the flasher they sold you is most likely what you need. 2001nbmz28 gave the right location for the fuse. if you have back up lights the fuse is fine. if the light gets brighter but does not flash when you use the turn signal put the flasher in it'll fix it.
