How can I tell if i have the LS6 intake?
Since he has a T/A, I doubt someone switched the ls1 intake on it for a ls1 vette intake. Just look for the egr provision. You definitely have one if you are a 01+ car.
Years 01-02 came with it STOCK. But if you have a 98-00 Look at the bottom of it. The Ls1 intake is curved the Ls6 is flat. Also there is a number on the top of the intake im just not sure what it is. Search and you can find it 10000's of people ask the same thing .
It's pretty easy....Look at your intake on your car. Right where the outside air goes through the Lid then MAF then the throttle body, then you have your intake. Right where the air goes into the intake right above that is there a hose connected to it? Should be the only visible hose you can see hooked up to the intake. If there is, you have an LS1 intake (see the 2nd picture to the left of the ratchet)
If there isn't one, you have an LS6 intake. As I said though, need more help just PM me man.
I have a 1999 T/A and I dont have egr provision and its looks all stock,,,but i have air pump into lid from exhaust so i had heard you didnt have air pump set up with ls6 ??? do I have one or just ls1
