***slp Line Lock***
***slp Line Lock***
im considering getting slp line lock on my 6 speed, what does everyone think? pro's con's ?? any input would be greatly appreciated
as far as slp's line lock, I had bad luck (it only worked 4 times then the valve stuck closed.Slp wanted to replace it for me but I said no thanks, took a $140 hit and went on with my buisness. Went with tci's unit, like it better and costs less($80) just my .02
SLP LINE LOCK INFO
I have great service with this
IS hole behind pcm , but I drill hole beside steering colum also ( drill from inside out ) put a peace of rubber hose in hole ran wire inside hose, then use same type wire wrap as GM,tie wrap to the big rubber hose comming over master cyl
I also mounted switch in ash tray
I have used this unit for 7 YEARS with NO problems ( well yes one problem :::SLICK tires )
PS ::Connect brake line to master cyl and line lock ,the second line which goes to ABS block start it but leave it loose,remove cap from master cyl and let the lines grivity bleed watch the loose connection untill all air is out and run pure fluid ( may shake the line a little to help bleed ( REMEMBER BRAKE FLUID WILL REMOVE PAINT
I placed plastic sheet over fender)if does not gravity bleed blow into master cyl and have some one watch for fluid at ABS block >>>THIS way you do not have to bleed the brakes from under car- I had no problem of any kind
also the picture from SLP is UPSIDE DOWN install with the wire connection UP
Sorry for the long post, hope it helps
