Cam selection MS4 or Trex..newb
Friend has a 2000 Trans Am with Hooker longtubes,custom y and catback. Had 4.10's but took them out for stock 3.42's. My or his question is what cam should he go with? He has a cam now(not sure of the specs) but it isn't that big. He's already changed the valvesprings so he wants the biggest cam he can get without flycutting the pistons. Are their better choices than the MS4 or TRex? His goals are low 12's high 11's and adding spray ini the future.
Also if he is an auto he should be thinking about a higher stall converter at the same time as the cam.
Thanks for the info/help guys I'll pass it along. He's an M6 car.... i'm actually texting him now to find out his specs on his current cam. This car won't be a daily just a friday/saturday car with some trips to the track.
With any cam that large, he's going to need to check the PTV clearance regardless of what the mfg says. Whether or not he'll actually have to is up for debate, but it's always a great idea to check with a cam like those.
He should really start reading up on cams. With a cam like that, also, he is probably going to want to swap back in some steeper gears than those 3.42s.
agree with pewter
both of these cams pretty much require a big stall converter (A4) or steep gears (M6), especially the TREX...the MS4 just sounds wicked and makes ridiculous numbers on cam swap alone. just my .02.
ms4 cam only doesnt make that much power for such a big cam. ive seen some make as little as 389-39xwhp, much smaller cams make the same. trex makes like 400-430 cam only
My cam only TRex runs 11.9's on the stock heads, intake, tb, has 4.30 gears and a good clutch. Mileager isn't bad either driving 150 miles each way and racing all day average is 15.3 mpg.
Alot more needs to be done in order to get the most out of a big cam like that. He'll also need at least and ls6 intake to take advantage of the higher power band. He'll have to go back to a MINIMUM of 4.10 gears. I'm one of the cars that "only" made 390 hp on an MS4. But that was through an unlocked and HORRIBLY inefficient converter. I've ran 12.0@114 mph on street tires and stock gears w/ 1.8 60' time at full weight (and I weigh about 300lbs, lol). I'll be swapping to a bigger converter here shortly (yank pt4400) and since that run I've added DR's, subframe connectors, and 3.73 gears.
He really needs to know what else he wants to do to the car. A big cam will definately outperform a smaller cam, but ONLY when it has the correct supporting mods to go with it. If he ONLY wants to change his cam right now, he'd be better off with something smaller.
