Damn panhard bar!
Old 04-16-2008, 12:31 PM
z28_YOU_HO's Avatar
Angry Damn panhard bar!
i cant get my pan hard bar loose..i tried with all my might to get this thing loose..the bolt toward the drivers side is STUCK..will not budge..hit it with a hammer and everything..havent tried sprayin it with WD40 though..i think i should try that..anyone have any pointers? the passanger side bolt came undone with ease..
Old 04-16-2008, 12:37 PM
getusumws6's Avatar
lube and air tools, its just rusted.
Old 04-16-2008, 12:40 PM
DUhulk78's Avatar
WD40 would help, just let it soak for a while. We used Conklins Rust Bomb a lot at the old dealership i worked better than WD40. Another thing that sounds crazy but actually works is to coat the bolt with beezewax and heat it up with a heat gun or something similar. Sounds crazy but works wonders when it gets into the threads.
Old 04-16-2008, 12:48 PM
z28_YOU_HO's Avatar
Yeah i gotta work on a few things on the car today..takin my catback off and all other sorts of BS.. but ill try soakin it in WD..hopefully that will do the trick..
Old 04-16-2008, 01:15 PM
z28_YOU_HO's Avatar
also, when adjusting it should i have it up on the jacks with the rear hanging down? or have the rear jacked up? and while taking the bolts off have it jacked up or the rear hanging?
Old 04-16-2008, 01:29 PM
RSbeast's Avatar
BIG *** BREAKER BAR, then air tools.
Adjusting, Have the rear on jackstands with them placed on the unibody so the axle hangs freely. Then jack up the rear until its where it would be. Then, adjust the panhard and it will move itself on the jack or the jack will pull with it.
Old 04-16-2008, 01:33 PM
z28_YOU_HO's Avatar
thats what i figured thanks
Old 04-16-2008, 01:59 PM
Reject's Avatar
go buy you some PB Blaster, like in the same area as the WD40.
wd40 is a lube more than a rust breaker. the PB blaster spray is desienged to break through rust
Old 04-16-2008, 02:01 PM
greg campbell's Avatar
Heat and wax, works every time. It will work with the girls in your picture too?! The WD-40 is just cologne.
Old 04-16-2008, 02:32 PM
z28_YOU_HO's Avatar
nah u just gotta whip out your meat haha
Old 04-16-2008, 04:27 PM
JD 01SS's Avatar
i agree with the PB blaster it is good stuff. helped break loose the manifold bolts on the old pos 76 when i swaped the motor. After almost 30 years of rust on them i only twisted off one bolt. Also get out the torch but becareful because most penitrating fluid is flamible
Old 04-16-2008, 04:34 PM
Krazy98Z28's Avatar
Heat it up!
Old 04-16-2008, 05:59 PM
Sunset'01Z's Avatar
it's a lot easier to do this if you jack the car up from the axle housing rather than the frame
Old 04-16-2008, 06:01 PM
z28_YOU_HO's Avatar
already did it up did it from the axle housing...how should i make sure it even..ive measured it but not 100% sure it exact..
Old 04-20-2008, 06:37 PM
Tnhillbilly's Avatar
Yep, PB Blaster is some great stuff! I use it all of the time!
Old 04-20-2008, 10:05 PM
jsteele90's Avatar
impact gun and some pb blaster.
Old 04-21-2008, 02:46 PM
Mr. Brett's Avatar
pb Blaster
Old 04-21-2008, 09:05 PM
Unertl42's Avatar
Thats the best, and takes the least effort
