Trans kickdown cable...
Old 04-20-2008, 08:14 PM
lunatik's Avatar
Default Trans kickdown cable...
This should be an easy one. All these times ive manually opened the throttle with the TB cam ive never looked at how the trans kickdown cable operated. The black box that clips on to the the TB cam -that holds the kickdown cable...is it suppost to actually "grip" the cable or is it suppost to let the trans cable slip through it as the throttle is opened? I just ported and polished my TB and the car runs fine except that it seems to not downshift as far or as hard as it did before I remove the tb. Any inputs??
Old 04-21-2008, 04:19 AM
lunatik's Avatar
anybody??
Old 04-21-2008, 07:46 AM
Reject's Avatar
if i'm thinking correct (it still to early) taht other cable is for your cruise control, and the other is the one that you are operating with your foot from inside being your accelerator pedal. these transmissions are electronically controled via the PCM. i think it may all be in your head.
good example is go look at your turbo hydro and you notice the cable for the shifter? and near by it it has the kickdown cable from the carb.
now go look at the 60e and notice it only has that shifter cable and a wiring harness on the other side....see what i mean?
Old 04-21-2008, 08:41 AM
lunatik's Avatar
I remember the th350's setup ('68 is in Ky). Your right. I thought more on it this morning and was wondering if it could be the cruise cont. I didnt trace it last night when i had the time. damn, now i gotta find out why it doesnt downshift all the way like it used to. thanks
Old 04-21-2008, 08:57 AM
BadGTho's Avatar
what car is this in? the LS1 cars have a TCM, no manual Detent
Old 04-21-2008, 02:47 PM
lunatik's Avatar
The car in question is the 99. sorry for the confusion.
Old 04-21-2008, 06:41 PM
lunatik's Avatar
Update... The downshift blues was fortunately a fluke. Its fine now and the P/P job seems to have paid off some. I still need to do the bump stop and I'm done.
