buzzing sound - LS1TECH
buzzing sound
Thread Tools Search this Thread
Old 04-28-2008, 09:23 AM   #1
bobbyd's Avatar
Default buzzing sound
well when i hit or put my foot on the gas pedal I can hear a buzzing sound. if I let go or remove my foot from the pedal the sound stops.
what could be the cause? driveshaft? rear end?
what could I check.
Like I said I dont even have to hit the gas as long as my foot is touching the pedal and putting a little force on it it will make the sound.
bobbyd is offline   Reply With Quote
Old 04-28-2008, 11:55 AM   #2
95GreenZ28's Avatar
Buzzing? Hmm maybe a u joint.
95GreenZ28 is offline   Reply With Quote
Old 04-28-2008, 11:56 AM   #3
95GreenZ28's Avatar
Have you checked for play on the driveshaft?
Old 04-28-2008, 11:59 AM   #4
tylerdj's Avatar
Buzzing? Like an electrical buzz?
tylerdj is offline   Reply With Quote
Old 04-28-2008, 12:15 PM   #5
bobbyd's Avatar
Quote:
nope not yet. how exactly would you check for that?
probably isnt a buzzing sound but it makes a sound like a whinning sound I guess?
Old 04-28-2008, 12:16 PM   #6
bobbyd's Avatar
Quote:
nah this is more like a whinning noise I guess?
Old 04-28-2008, 12:18 PM   #7
tylerdj's Avatar
If it's a whining sound it's more than likely your differential.
Old 04-28-2008, 12:28 PM   #8
95GreenZ28's Avatar
Grab your driveshaft and twist it from side to side. If you have alot of play there it is prob your u joints.
Old 04-28-2008, 12:45 PM   #9
bobbyd's Avatar
will try this later today and report back
Old 04-28-2008, 12:47 PM   #10
z28_YOU_HO's Avatar
edittt
z28_YOU_HO is offline   Reply With Quote
Old 04-28-2008, 12:55 PM   #11
tennz28's Avatar
I had a high pitched wine noise and it got louder as I pushed on the gas and softer as I let off the gas. It was coming through the speakers so I knew it was electrical it turned out my battery connections were corroded to hell. After i cleaned them off the noise went away......not sure if its the same noise you have going on just thought id share.
tennz28 is offline   Reply With Quote
Old 04-28-2008, 01:00 PM   #12
LS1>girlfriend's Avatar
Quote:
ring gear teeth are sharp....be careful
LS1>girlfriend is offline   Reply With Quote
Old 04-28-2008, 01:12 PM   #13
bobbyd's Avatar
Quote:
hmmm will try this aswell since that sounds about right the more you hit the gas the louder it got and the more you let go the softer It got.
Old 04-28-2008, 01:36 PM   #14
tennz28's Avatar
Yeah it was driving me crazy, clean the terminals and put some anti-corrosion spray on it. Worked for me...
Tags
55, buzzing, foot, gas, gmc, hear, high, hit, noise, pedal, sierra, sound, tires, whirring, yzf600r
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
