LQ9 to LS6 intake Conversion help!!!
Old 05-02-2008, 10:44 PM
atp
atp's Avatar
Default LQ9 to LS6 intake Conversion help!!!
I have a LQ9 from an 05 Denali that I am putting in a 70 2wd Blazer. I had planned on leaving the stock intake on it but am considering putting a LS6 intake on it. What all would be needed to make the switch??
Old 05-03-2008, 12:11 AM
the_merv's Avatar
You will have to change the Water Pump. With doing that, more than likely it will be an F-body one that you will be able to get ahold of for cheap, so you will have to go with the F-body Acessories, Acessory Brackets, and Crank Pulley as well.
Old 05-03-2008, 07:46 AM
atp
atp's Avatar
I have the new March LS pulley kit for camaros with all the accessories so that part would be covered. Curious why change the water pump? Is it a clearance issue?
Old 05-03-2008, 09:03 AM
89 formula350's Avatar
the rad. hose (pipe) will hit the tb/cable cam area if using a truck waterpump.
