Head light problem, help
A wire from the wire harness for the headlight has come loose, the head light is stuck down and I cant pull the harness out from under the car. What else can i do to fix this problem?
There is a piece behind the light when you open the hood. it is has a round boot with a piece sticking up on the boot. take that boot off and you can open the headlight manually there.
you could also get to it from beneath the car...there is an opening in front of each tire that i think has 2 10mm bolts on it that you can losen and see up into that area from beneath if you cant get to the wires from the top
