A couple dumb newb questions
Old 05-13-2008, 02:18 AM
Bmx4Rizzo's Avatar
Default A couple dumb newb questions
So I dont have a manual and I cant find it in a haynes, sooooooooo how do I stop my headlights from opening up everytime I unlock and lock it. Last thing how can I get my foglights on without the headlights coming up? My friend has a lt1 TA that the fog lights will come on without the headlights coming up so im confused. Thanks-Tim
Old 05-13-2008, 02:22 AM
TA-Swede's Avatar
Downloadable manuals for your car (look for the different "modes" the alarm can work in):
http://www.camarohighway.com/Manuals/
Fogs without headlights.. Only way I've been able to do that is to have the parking-lights on when switching on the fogs.
Old 05-13-2008, 02:45 AM
Bmx4Rizzo's Avatar
How do you make the parking lights come on?
Old 05-13-2008, 03:01 AM
TA-Swede's Avatar
Turn the light-switch to the middle position
Old 05-13-2008, 03:10 AM
Bmx4Rizzo's Avatar
When I move it into the middle the headlights pop up
Old 05-13-2008, 03:14 AM
TA-Swede's Avatar
Wierd. Mine doesn't..
Old 05-13-2008, 11:35 AM
Bmx4Rizzo's Avatar
Thats why im confused
Old 05-13-2008, 11:39 AM
bobbyd's Avatar
lol I just asked the same questions in a thread today im having the same problem as you
Old 05-13-2008, 11:43 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
Are you having headlight motor issues? ie, not wanting to open/close or grinding?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 05-13-2008, 11:48 AM
WS6R6's Avatar
Make sure you go from the off position to the middle position. If you go too far and then move it back into the middle position, then the headlights will come up but will not be on. They shouldn't pop up unless the switch is moved into the 3rd or rightmost position. The fog lights can be turned on in the middle position without popping up the headlights.
DevilDougWS6's Avatar
do the lights come on when they pop up with the switch in the middle position?
Old 05-13-2008, 11:49 AM
Bmx4Rizzo's Avatar
I know but they do. Thats what im trying to figure out
Old 05-13-2008, 11:51 AM
Bmx4Rizzo's Avatar
Nope.
Old 05-13-2008, 06:55 PM
teh PuRpL3z
DrEvyl's Avatar
You probably need to replace a headlight motor. If it makes a lot of noise, that's definitely it. They should not open when you hit the lock button.
Old 05-13-2008, 10:38 PM
TireSm0ke's Avatar
A headlight motor? no way. It would need the current to power the motor to open and close the headlights. This is a very common problems with our cars, and I do not know the cause. It has something to do with the way the factory alarm was rigged. I know there is a how-to thread on how to change this... search is your friend pal
Old 05-14-2008, 08:19 AM
sounds crazy, but it is a somewhat common issue for the headlights to do that is a motor is going out, that's why i asked the questions I did above.
__________________
Old 05-14-2008, 10:59 AM
my bandit's Avatar
if you have a trans am the way that you can have the fogs come on is by just flipping the switch to the on position under the headlight control to have them flash when you unlock it and to drive with them on just turn the **** 1 click not 2. for the headlights coming up when you unlock it. i dont know how to help you there
Old 05-14-2008, 04:19 PM
SSkillz's Avatar
samething happen to mine it was a motor that went bad.
Old 05-14-2008, 04:22 PM
nitrouspowrdss's Avatar
The cause IS a bad headlight motor. It is GMs way of saying fix your car...
Old 05-14-2008, 04:41 PM
Thank you Most everyone skips my post when I ask that, as did this guy. Understandable cause it sounds like it doesn't make sense, but it is a common issue and that's the common cause.
__________________
