New Products Showcase Come inside to see the newest hardware!
Iron Block 427 $3499.99
Old 05-13-2009, 11:35 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Default Iron Block 427 $3499.99
7.0L 427 Stroker Short Block (Cast Iron)
GM 6.0L NEW Cast Iron GEN III Block (4.065 Bore)
Eagle 4.125" Stroke 4340 Steel Crankshaft
Eagle 6.125 H Beam Connecting Rods
Mahle Forged Flat Top Pistons -4cc Valve Reliefs
1.5mm Power Pack Ring Set Suitable for Limited Nitrous Applications.
ACL H Rod & Main Bearings
Digitally Balanced Assembly
Fully Assembled
Accepts LS1, LS2, LS3, L92 Cylinder Heads
Add $275.00 for Crank and rod Armor Coating this option also includes a 1 year limited warranty against rod and crank breakage.
Now Available.
Aluminum Block Option: Add $1000
NOTE: LS1 to LS2 conversion kit may be necessary for vehicles 2004 and newer.
LS1 to LS2 conversion kit includes: LS2 timing cover kit, valley cover, LS2 gear and chain set, lifter guides and cam sensor extension wire add $295.00
L92.502 high volume oil pump add $105.00
Hellfire rings add $100.00
Old 08-11-2009, 08:41 AM
LS1TECH Sponsor
We now have all the parts available to make up these shortblock kits.
Up to Thanksgiving, we are offereing FREE SHIPPING to the lower 48 on shortblocks over $3300
Just $100 for shortblocks under $3300
Old 09-11-2009, 09:51 AM
LS1TECH Sponsor
updated shipping on shortblocks
Old 09-17-2009, 05:45 PM
LS1TECH Sponsor
Just got off the dyno with this shortblock with LS3 heads and an L92 intake manifold.
It made 545hp and 580 ft-lbs with a very, very small cam, a 212/212 on a 112 with 560 lift!!!!!!
Customer wanted torque, and he got it.
Quick Reply: Iron Block 427 $3499.99
