New Products Showcase Come inside to see the newest hardware!
New Virginia Speed engine packages.
Old 09-14-2010, 08:39 PM
Shawn @ VA Speed's Avatar
Default New Virginia Speed engine packages.
New engine packages from Virginia Speed.
through years of research and development,we bring you some of the best engine packages on the market
2000 hp 427LSX Forced Induction
this engine is for the guys that want a ton of hp but and drive it on the street from time to time
Features
GM LSX block fully cnc machined
Lunati Pro Series Crankshaft 4.0'' stroke
Oliver Billet rods
Custom JE pistons
Total Seal stainless piston rings
Mast/Performance Inductions ls7 6 bolt heads
Crower solid roller lifter
T&D shaft rockers
Cloyes timing chain
1/2'' head studs
ATI balancer
Aviaid 4 stage dry sump oil system
Virginia Speed main girdle
Marcella custom intake
Cast aluminum valve covers
$28,000.00
add $2500.00 for RHS aluminum block
2400 hp 427 LSX Forced Induction
proven low 7 second power
Features
Bryant billet center counterweight crankshaft 4.0'' stroke
GRP aluminum rods
Custom JE pistons
Crower solid roller lifters
Jesel shaft rockers
Jesel belt drive
Jesel belt drive distributer
1/2'' head studs
ATI balancer
Aviaid 5 stage dry sump oil system
MSD crank trigger
$33,500.00
2700 hp 427 RHS Forced Induction
6 second player,just add a pair of 88mm turbos
Features
RHS 9.2400 deck block fully cnc machined
GRP aluminum rods
Custom JE pistons
Mast/Performance Inductions C5R splayed valve 6 bolt heads
Crower .903 solid roller lifters
Jesel shaft rockers
Jesel belt drive
1/2'' head studs
ATI balancer
MSD crank trigger
$38,000.00
3000 hp Billet 450 Forced Induction
Baddest of the bad
Features
Billet 9.7500 deck block
Bryant billet center counterweight crankshaft 4.125'' stroke
GRP aluminum rods
Custom JE pistons
Mast/Performance Inductions "MOZEZ" canted valve 6 bolt heads
Jesel keyway solid roller lifters
Jesel shaft rockers
Jesel belt drive
1/2'' head studs
ATI balancer
MSD crank trigger
$46,000.00
750 hp Naturally Aspirated 460 RHS
For the guy that wants everything-power and great street manners
Features
Lunati Pro Series crankshaft 4.185 stroke
Oliver billet rods
Custom JE pistons
Mast/Performance Inductions C5R cylinder heads
Lunati high rpm Hydraulic roller lifter
Jesel shaft rockers
Cloyes timing chain
ARP main and head studs
ATI balancer
Melling oil pump
Oil pan to fit specific chassis
102mm throttle body
60lb fuel injectors
Dyno tested
$35,000.00
Quick Reply: New Virginia Speed engine packages.
