New Products Showcase Come inside to see the newest hardware!
E-38 Stand Alone Wire Harness $510!!!
Old 12-20-2010, 07:52 AM
LS1TECH Sponsor
Schwanke Engines's Avatar
Default E-38 Stand Alone Wire Harness $510!!!
For those looking to get your newer truck or car engines running in those swap projects, here is the affordable answer!!!
58X E38 wiring harness only $510.00!!!
Kit includes:
Custom stand alone open loop only wiring harness, no O2's to worry about
40" long from rear of engine to PCM connectors (allowing easy installation)
4 fuse pannel
ALDL connector
Fuel pump relay
3 wire, 2 batt power and 1 switched, hook up with 1 fuel pump wire and tack
Choice of 3 injector harness leads (Specify Injector Plug)
T-42 4L60E Transmission Harness add $149.99
T-42 Automatic Transmission Module add $145.00
58x Complete Harness and Fuel System Kit add $539.99
(Includes PCM with base tune, fuel pump, regulator kit, line and fittings)
Electronic Throttle pedal add $85.00
Give us a call or go on our Ebay page and buy one today.
