Carbon fiber valve covers
STRONG, LIGHT, DOESN'T RETAIN HEAT: GET PERFORMANCE AND STYLE
Granatelli Motor Sports is proud to announce our new line of carbon fiber valve covers. Each set is produced using proprietary VRTM molding techniques developed at our facility in southern California. The carbon fiber valve covers have cast aluminum internal ribs that create the structure required for perfect sealing on the street or on the track. They are 3/4" taller than stock, so they will clear roller rocker systems. Compared to stock, our LSX valve covers weigh an amazing (1)lb. An optional stainless steel coil mount system, is available for LS applications so they will work with our Granatelli High Output Ignition Coils. Unlike billet or heavy traditional cast valve covers, the carbon material doesn't hold heat. This allows the valve covers to cool to the touch quickly at the track for any needed valve train work. Being non-corrosive, these covers also make an outstanding upgrade for marine applications. All mounting hardware for the valvle covers are included, so installing the valve covers is as quick as removing the stock and replacing them with our valve covers.
Currently, we cover the following applications:
GM LS, Pontiac Big Chief, Big Block Chevy, Small Block Chevy, GM LT1-4, Ford Yates, Small Block Ford, and Oldsmobile. We have more applications coming, so please call and ask if we have something for your application. You can contact us at 805-486-6644 or sales@granatellimotorsports.com with any inquiries.
