CBM Motorsports 92mm clockwise rotation T.B. adapter.
CBM MOTORSPORTS
Throttle body adapter.
Custom billet adapter for 92mm throttle body. This adapter allows clockwise rotation of the throttle body when clearance is needed for a high mount accessory such as an alternator, ac compressor or power steering pump. This adapter will work with any four bolt intake manifold (LS2, LS3, LS7, LS9, L92, L76, L99, FAST, etc.) with the exception of the LS4. CBM billet throttle body adapters are proudly made in the USA from a solid piece of 6061-T6 aircraft grade aluminum. This adapter is 3/4" thick and milled on every side to ensure a perfect seal. We have designed this piece with an o-ring for a leak free seal and no messy silicone.
Mounting hardware and o-ring included.
FOR MORE INFO.
FOR MORE INFO.
