UMI Releases New Product- Bolt In Rear Shock Relocation for the Camaro/Firebrid
Bolt-in Rear Coilover Brackets for the 1982-2002 GM F-Body
P/N 2047 priced at $39.99/set
UMI Performance, Inc is proud to introduce our P/N 2047 GM F-body bolt-in rear shock relocator kit. This kit rotates the factory style rear shock to reduce the common problem of lower shock mount binding. The shock is relocated to a double shear mount and pivots freely about the lower bolt. An innovative, TIG welded lower bracket holds the shock in double shear and works with standard axle mounts as well as with most common relocation brackets (spacers included). Drilling two 3/8” holes is required (no welding). The P/N 2047 kit accommodates a standard 1-1/4” wide shock mount and has ½” diameter mounting holes. Hardware is included. All UMI components are 100% manufactured in Philipsburg, PA-USA.
1982-2002 GM F-Body Rear Shock Relocation Kit, Bolt In
