MISHIMOTO OIL CATCH CANS @ coloradoSPEED
LS1Tech Sponsor
CLICK >>> MISHIMOTO OIL CATCH CANS <<< CLICK
Mishimoto has developed oil catch can to make sure you’re getting the most out of your performance parts.
Over time harmful oil will build up inside the turbocharger, intake manifold, intercooler, and piping. A Mishimoto oil catch can will prevent this from happening by separating the air from the oil.
An oil catch tank serves other important purposes as well. It will prevent oil from getting into pressured turbo plumbing, which can lead to couplers coming off under boost. Oil vapors can get into the intake system, which will lower combustion temperatures and reduce overall efficiency. A Mishimoto oil catch can will solve all these problems and give you the added security knowing that your performance parts are safe from harmful oil.
Every turbo system deserves to be complemented by a proper oil catch can setup, also known as an air oil separator. An oil catch can prevents oil from accumulating in the air intake tract, which would have a negative impact on the efficiency of your intercooler. Once the oil reaches the combustion chamber, it will have an adverse effect on the fuel air mixture. Both issues can be avoided easily by installing a Mishimoto oil catch can tank or an air oil separator. Our catch tanks include all the necessary hoses, clamps, bracket, and hardware for your custom install. As with our overflow reservoir tank, the catch can is offered in several unique finishes, including aluminum, black, and carbon fiber. The oil catch can and radiator tank add style and practicality to your engine bay.
